Ouch
this may have helped you out on keeping the damage down.
Who makes this bumper?
Ouch
The skinz bumper uses a second mounting location other than just the cast tabs. It still uses the factory tube that attaches to the lower part of the bulkhead which in my opinion is too weak. I smoked a tree with mine and I feel that if that lower tube was stronger it would have saved my pipe as the bumper crumpled down.
Heres the pics. Probably going to go with a VE bumper for next winter
your f'ed. if you weld it back on most likely the adhesive in the (lets just call it over structure) could melt or be weekend. I have a totaled sled that has NEVER taken an impact other than jumping. The over structer is week, the cas piece that joins the 4 bars and locates your steering post/handlebars is a POS. The actual cast bulkhead is strong and requires a direct impact to hurt it. It will flex and put the damage else where. You will get broken running board brackets, flexed tunnle or "dog legged". broken chaine case, broken cast aluminum muffler bracket, bent "overstructure" and like MH said, thsoe tabs are a joke. This IS the cost of us demanding lightweight.
Excuase my less than thrilled outlook but polaris owes me a sled. There is no reason someone should be able to total a polaris assault by jumping it. I have no broken bones, therefore the sled shouldn't either. If randy sherman is aloud to jump roads and drop cliffs in the promo video for the sled, shouldn't i? ohh well, guess i will start building "ms america", the baddest free ride sled you guys will ever see![]()
For the guys that are running the Van Amburg front bumper, what if you have factory skid plate on? Will the skid plate be in the way, or can it be mounted over the skid plate???
For the VE bumper, early reports said no instructions on where to drill that lower hole??? anyone have that figured out yet or do they come with decent instructions now. Nothing like drilling some big holes in the front of your belly pan in the wrong spots.
FDX... do you have one of the VE bumpers?
I have the same bumper and was also worried about using the stock center tube as well. Did you hit the tree at a decent speed? Could you ride back to the truck?
MH I'm running Airframes on the Pro. I have always thought it would be nice to tie a wider bumper all the way back to the Airframes. Run a bar low on the side panel. Also, I have always thought that some kind of sacrificial bar should go out far enough to protect the lower a-arm. If the bumper was tied in to the front structure, maybe upper shock mount and the Airframes it seems like it would be super strong, protect the pipe, a-arms, and the TUNNEL right at the footwell where it kinks most of the time. Am I missing something?
