Any feedback on the twin link steering system, was the steering ease comparable to your X model or seem heavier?
Ya, everyone heard it.
It was a BRAND new sled with no miles on it.
At first I thought the paddles were touching.
Just needed to be fine tuned for the day's ride.
What is the new price range of the machine?I did not.
They only offered me the opportunity to ride the Expert.
The day got squirrely and I did NOT get a chance to ride the Expert on any trails.
So I have no clue if that 32" front end is TIPPY or not on hard pack
While I LOVE riding in the mountains and the trees, the hard cold reality is I ride a LOT of trail miles every single time getting TO and FRO the places I like to play in.
So Trail Behavior is important to me.
Warm up your pocket book! Having fun is getting expensive. Oh well. You only go around once in life. Be Safe. Headed you way in March. Took your advice. Come on out!
WILDLY EASIERAny feedback on the twin link steering system, was the steering ease comparable to your X model or seem heavier?
FACTWarm up your pocket book! Having fun is getting expensive. Oh well. You only go around once in life. Be Safe. Headed you way in March. Took your advice. Come on out!
I'd like to see that same steering setup but in a 34 inch front end on the X model.WILDLY EASIER
While I was riding a TURBO EXPERT, weight wise, I THOUGHT I was on an NA. The front end "FELT" that different
Buy a lynx. They have it.I'd like to see that same steering setup but in a 34 inch front end on the X model.
There is a lot to like about the Lynx but it is about 20 pounds heavier and you do not get the new rear coil suspension.Buy a lynx. They have it.
7 pounds heavier than the expert. Suspension will ride better than coilover.There is a lot to like about the Lynx but it is about 20 pounds heavier and you do not get the new rear coil suspension.
I was comparing it to the X.7 pounds heavier than the expert. Suspension will ride better than coilover.
Not in Powder but they make a good trail sled.Why doo you think that Lynx suspension setup will be better?
I don't know that it will be better. They soak up bumps better. They claim to have worked over suspension to climb up on snow better which was much needed. The ds might be cool. No thanks on re. Great trail sled.I was comparing it to the X.
sigh, And as far as a chain tension procedure, is the same between the rexnord and the borg warner, they are both chains. Difference is one is called a silent chain for a reason.
Well we all better remove the hyvo chain then and go back to a silent chain to prevent slider wear.if you can hear the chain whine, its too tight, period. The slider will wear out. I have seen these cases already and more is coming.
The hyvo has been used since 2020 in the turbo.
