Building my first turbo sled. How to get the fuel supply correct?
Alright. Let me start by saying that I'm used to doing turbos and superchargers on cars and trucks with EFI. I've never done anything with a carb.
So, I'm starting with a Garret T3 turbo. I'm making a custom exhaust ( a perforated down pipe that turns at a 45 degree angle to keep some back pressure while not being obnoxiously loud.
I will be using a small car fuel pump running off the battery of the sled for the oil pump for the turbo.
Now, how do I keep my jetting correct while running boost? Is there a compensator I can get that will still work properly under boost?
What about my powervalves. Will those work properly under boost or should I eliminate those?
Any other tips to a first timer would be great.
It is a 600 Non-H.O. Ski-Doo motor. I plan on running a mix of 91 and 110 octane and will work with compression and port timing until I get that spot on for the most power with no detonation.
