Build a DIY bullet proof 800 CFI
rab
I have been nominated to build my friends 2014 800 cfi that has gone south twice ,
once on the factory build and the 500 miles later on his build .
I will list the Mods that i have seen on here to help prevent this from happening again .
Please feel free to add in any that I may have missed
shim kit and longer rods
shim kit and taller pistons
wossner pistons
newer monoblock with tighter tolerances
newer OEM pistons with thicker skirts
BRP T-Stat mixing valve
Oil tank venting
Oil pump stroke indexing increased approx 3 turns
is there a way to reduce the lash between the brass center drive and the cross shaft that drive the oil and water pump ?
how much las are people seeing here ? lets say we use a clock as an index template on the water pump impeller , this one has approx 5 min ish
all regular build parameters will be observed like , ring end gap , piston clearance , cylinder head to piston squish , OEM TPS setting . no sealant in the mag oil port!! , circlips at 12 or 6 oclock , oil everywhere and cleanliness observed , and proper torques , did I miss anything ?
why has it gone south twice ? same things wrong both times?
I don't think their is anything wrong with a 14 cylinder, its the 2012 and older known to have breaking tabs?
if your getting a newer cylinder let me know I may buy the old one.
bullet proof CFI ? - im supprised all the indy dan long rod three year waranty guys arnt going bananas here.
i am at 4000 miles and just got fitted pistons in my top end, next time round will be at 6000 miles a redone mape crank and again new pistons and redo the water pump - if all goes as planed.
good luck whatever way you go with your bullet proof effort
If you really want Bullet proof, forget DIY, and send it to Indy Dan
An Indy Dan Blueprinted engine is not "DIY" as the OP asked for. But they are as close as you're ever going to get to "Bullet Proof" (assuming you take your head out of your AZZ, and follow his directions and don't sabotage the build yourself due to ignorance)!
The Average Joe does not have the machine shop access, measurement tools, nor knowledge to truly get a bullet proof build. IMO
often motor, high output, bulletproof, long life, just don't go together, i use a machinest to measure my stuff, it takes a variable out of the mix and i use other profesionals as needed, my hat is off to anyone who will dig in on a modern sled and just do it, if a shop built me a 500 mile motor you can bet i would be putting the next one together.
maybe bullet proof was to strong of a term !!
I am just trying to build this motor so it lasts longer than it did .
I'm not sure why it went down the first time, but this time around the Mag side piston is scored on the intake side , and the crank bearings are rough , one of the shims were missed on the rebuild and the center brass gear has abnormal wear on it .
I am sure that Indy Dan long rod motors are top notch , but that option is to expensive for me up here in Canada .
I'm just trying to find out if there are any other things besides the ones I listed above can increase the life of this 800 CFI .
How do I differentiate between the Mape crank and the Fugi crank ?
Part number difference, for one, that is Laser etched into the square face of the crank where the clutch bolt enters the crank shaft.
Additionally;
The Fugi crank is faced square at the end of the taper.
The Mape crank is faced square but has a small protruding step around the clutch bolt hole.
  • Like
Reactions: rab
Mape cranks in the 800's ended in late 2012 or the Fuji cranks started on the 2013 model so by 2014 you should have the better Fuji .
I seen on eBay long rod cranks and they also had rod kits With longer rods from Utah crank , so if your building a crankshaft any way how much more to go long rod? I think if it's quality parts it should extend engine life .
As a note the Fuji Cranks need the taper lapped to fit the clutch. The Mapes cranks don't, usually.
Turn oil up 3 turns
Vented oil cap (Paaso Racing)
MTNTEK Fix Kit
High quality oil
Very thorough warm ups with the forged pistons
Ensure proper primary clutch balance
