broken ski rubber
Just get a set of SLP Mohawks. Much better skis and much better rubbers. Two problems solved at once.
I found the slp ski’s to be darty on hardpack and have increased steering effort.
That’s good you like them though.
Sure is a lot of folks out there with stock ski’s who appreciate a fix without spending coin on new ski’s.
has anyone got a hold of gulfi dropped a pm and haven't heard back?? the season is creping up and im hoping to get them sooner than latter!! {any other way to get a hold of him}
Ski Spindle Pads from Skinz
If you are looking for a better fix, and one that is easier to get a hold of, check these out! They sit down into the ski's, and give the rubbers a flat surface to press against. They are designed to keep the rubbers from blowing out!
They are 75.00 bucks!
Sorry, but that's the silliest thing I've seen today. A flat bar of 1/16" aluminum will do the exact same thing for maybe $5. Filling the voids does nothing, but if you really want them filled, squirt in some silicone before you place the flat bar over the top.
I have a SBA that's going on the third season with a thin piece of UHMW instead of aluminum. Didn't fill the voids and no issues.
I put a thin piece of steel in mine without filling the voids, think it made my problem worse. Water would get in there, freeze, and put even more pressure on the mounts.
Great day yesterday carving through some dense pow with no ski stuffing issues. [emoji4]
The polyurethane is the way to go.
Well the ski’s got used sometimes.
Note the perfect ski position.
Zero sag or flopping.
That will never last with a rubber based material ski damper.
I tried the skinz thingies.
We were riding in Buffalo Pass and split a ski rubber. Went to kremling and picked up two sets of new ones. And skinz thingies. Took about 2 hours of riding and downhill turns before we wrecked the first one. By the end of the day all of my rubbers were junk. Two sleds. 4 rubbers and 150 bucks for aluminum. Not the answer for us
Sent from my iPhone using Tapatalk Pro
