Any ideas as to why a clutch puller would break? It's brand new... once we have the puller out what would be the best way to remove the clutch???
The split clutch puller looks like you've been using a rattle gun on it and then hitting the end of it with a hammer; trying to get the clutch to pop off. NEVER USE A RATTLE GUN on a clutch puller. Your crankshaft is split (two pieces) and a rattle gun can twist your crank out of time. I've done it, not good.
When using a clutch puller,
#1 Grease the tip so it doesn't bind when in contact with the end of the crank and make sure all threads are clean
#2 If it just won't pop off and you've got it as tight as you can get it, use an aluminum drift and a steel hammer to tap on the exposed shaft of the fixed sheave, rotating the engine slightly everytime you hammer on the drift. Don't hit it too hard, as this can damage the pto crank bearing. You can also use heat on this surface, but nothing hotter than a propane torch.
#3 When getting ready to reinstall the clutch, clean the tapers on both clutch and crank really well, then take a piece of chalk (regular blackboard or sidewalk chalk) and rub it over the tapered surfaces. This will keep the metal to metal contact of the tapers from fretting. Machinists use this method all the time when using tapered shank tools in their mills and such. Your clutch will come off easier next time.
s-a
Finally got the puller out, this is what I did for those of you silly enough to do what I did (lol) Snapon sells 12" drill bits and that is what I used ,had to drill the entire puller out took a long time but finally got it. Then I used a three prong puller to get the rest of the clutch off. I have to replace the inner and outer faces but it should be fine.
Ps Put grease on the end of the puller and use heat(not to much) and save yourself a whole lot of time and money.
