C
we use to wire our nitrous up so when ya turned the high beam on it would arm the system then full throttle would trigger the shot. old days.
cool idea but I dont think its worth all the hassle. ive never been in a spot where i wish i could of turned up my boost in the middle of the same day nor anyone of the other turbos ive ever rode with. changing the maps only takes a minute with these things if ya ever wanted to run a higher hp map.
Correct, but the only way you can load a completely different map into the vipec is if you want to ride with the laptop and upload a file. And you have to power off the ecu and connect to it without the engine running (requires a battery) to upload a COMPLETELY different map.
So for simplicity it makes to be able to toggle between high and low boost.
