C
I've been reading a lot of thread lately about some of you wondering how the vipec can control boost for your turbo kit. Well there's really two different strategies that you can use to control boost. Open Loop and Closed Loop. Open loop just hits a given duty cycle that you configure to your solenoid in your DC map. Closed Loop uses a PID alga rhythm to maintain a "target boost" that you input. I'll keep it simple in this post and just talk about open loop.
You can configure the X and Y axis to whatever you want parameters you see fit. A good way to do this is to use either load or TPS on the y axis and rpm on the X axis. 10% will be your minimum duty cycle for your turbo/wastegate combination (or base boost). 90% would be your maximum duty cycle (max boost). Let's say you do some testing and at 10% duty cycle you have a minimum of 6psi and when you change your duty table to 50% it gives you a boost setting of 12psi. You can interpolate the duty ranges and get a nice smooth boost curve and basically program any instance you'd like to change boost, i.e., a boost switch. A lot of guys really don't want to have to reach down and hit a switch or let even drill a hole and mount another switch in their pricey sled. So I thought of a quick and easy way you can get the vipec to do the work for you without installing any additional hardware or wiring. It's basically a configuration that you can use in a "push to pass" situation or if you're struggling to climb a big hill and you know you're not going to make it.
I put together a quick little video just illustrating this scenario. With just a flick of the brake lever you can now have increased boost. I've also configured this with a timer so you can set how long you want the increased boost and it will automatically turn off.
Hope this helps you guys!!
http://youtu.be/99KrmZq7csw
