05rmksteve
Yes.Is this a OEM crank?
Get me the part# off the end of the pot shaft. It's where the clutch bolt screws in. I can double check fitment tomorrow.
I’ve ran the 13/1 head on 90 octane non ethanol at 500ft with no det on a 2013 600 pro.
It should say on the top of the domes what the ratio is if it’s a mds/par head.
I think that’s a 13.5 head call Steve at mds
Looks like the rod bearing went out, caused the piston to go out of time and detonated the crap out of it. Common problem.
It sounds like you aren't too deep in it. A Carl's 660 would be nice. Or OEM parts (pistons) brother.
Dude that 600 engine on ebay is a good deal. If you talking about replacing the crank... I say just order that used one. Seriously engine failures on these are pretty darn rare. Id be scared of everything on the engine you have. It looks like someone either didn't know what they were doing when they put it together... Or there was some fabricated verbiage to get you on the hook.
Either way... I say buy that engine off ebay. Slam it in wham BM on the snow. You still have your pile of junk to play with for spare parts. And it sounds like a good place to start a 660 build in the off time.
Let me know if your interested in that crank I'm heading out tomorrow. I also have a cylinder would just need the # off yours to make sure there the same. Pm me.
Or there is this option ?
https://m.ebay.com/itm/13-14-15-POL...?_trksid=p2385738.m4383.l4275.c10&_mwBanner=1
So I guess the motors went from a 4 injector system on the 2010-2012 600’s to a 2 injector system on the 13+ motors. So no go on the eBay one I guess.
