Thank you for all the ideas GoBig. I will start working down your list to see if I can find any issues.
My afr gauge goes full lean during this bog, my fuel is @42 and my green and yellow are at 6, I've even maxed out the green, still comes and goes when under load.
got a 07 M8 Turbo have the garett 2871,race gas set up with intercooler old style, horrible bottom end mainly at start off in powder any way to get a lil bit crisper start off, boondocker controller i puled a lil fuel at 3000 seemed to help a bit but dont want to go to far, its hard to get movin if i stop in deep snow once it moves 3 foot or so it takes off fine its just the initial take off..
110 trick, 8-10 lbs boost(bd box says max 8.2psi, 10.4 peak but seeing 10 on my gauge), stock secondary, tip weighted cutler weights in primary, 153 track, ez ryde,
I have a 2008 M8 Race Gas Boondockers Kit, 13 psi, 8000ft, 3/4 100LL rest 91 pump with the big *** intercooler. It isn't your intercooler, because I've had mine running where it would pull a wheelie out of deep powder from a dead stop even with high 62/58 gears. Now, there always is a tad bit of turbo lag, like a second, but it should hit like a rocket went off once boost builds. Mine started developing a huge bog when I ran into electrical problems and my fuel pressure started fluctuating. You should see a firm 40-42 psi, I run 42. If it shakes back and forth from like 38-42 that won't cut it either. It has to hold 42 or whatever you set it at like a permanent line was drawn on your gauge, at least that is how mine is when it runs good.
Have you replaced your pipe sensor anytime soon? I've heard that when those start to go out they can think you are running too lean, add way too much fuel right off the start, flooding it and cause a bog. There is a thread that tells you where to get Duramax diesel ones for cheap that apparently have the same specs as the Arctic Cat ones, like $30.
Also, when my diamond drive started to go out my sled acted like it had a huge bog, but it was metal shavings in the DD locking it up. I would get stuck all the time, I thought it was tuning trouble because the sled acted like it had no power in deep snow for like the first 5 feet from a stop, then the metal shavings would clear out and it would pick up. Then the DD completely locked up, I punched it and started smoking my belt on a flat trail. I rebuilt my DD and my sled immediately lost the bottom end bog...
What about your power-valves? My brother had a sled and his power valves got stuck wide open for some reason. It had a horrible bog until he figured out what it was...
I've also had baro tube trouble. Same thing, but ran kind of crappy bottom and top, water in the line...
