boss or custom seat for '98 700 rmk
Jay
Does anyone know where I can get a lightweight highrise seat for a '98 700 rmk. I contacted boss but they say they aren't building custom seats anymore, or at least now. Are there other manufacturers out there that can build me a seat similar to the boss highrise style? Any info or help is appreciated. Jay
Get a hold of WRP (Wasatch Recreational Products - www.wr-products.com) and see if they can help out. I put one their seats on my GF's '02 600 RMK.
I forgot to mention this seat is the Edge +3 seat - 3" taller than stock. They also have a +4 seat as well.
Also saw that Skinz makes seats as well.
yeah looked up both for the rmk and the m cat, you buy yours new? easy install
Piece of cake. You do have to drill the holes for the seat bracket. The only issue I had was some joker at Polaris ran the tail light wiring through a 3/8" - 7/16" hole in the plastic on the bottom of the stock seat. The plug under the seat would not go through, so I cut the wires, soldered them back together, used some heat shring on each wire and then some heat shrink on the bundle. I also put on a piece of split loom and used a protected P-clamp with the bolt in the rear right stock seat mounting hole.
I forgot to mention that two holes need to be drilled for the front seat mount as well, but still easy to do.
