Boosted RX-1 Mtn questions!
A
AkHockey10
ok...so lets say im gonna buy an RX-1 Mtn and boost it for my ride next winter. (just something im kicking around...i may do it, i may not)
Should i go with a turbo or super? (whats cheaper? lol)
Whos kit should i go with? (i would like to be in the mid 200s as far as hp)
Whats the difference with the front mount, side mount, rear mount?
and yes, it will be an RX-1 or a Warrior Mtn pretty much stock except for the boost.
ride safe!
Your gettin all crazy on us huh?
A super will be cheaper brand new compared to a new turbo but try and find a used turbo and you will be happier.
Any turbo kit will put you well into the 200hp levels. Front mount has less lag more heat but fun to ride, side mount about the same as a front, rear has more lag and less heat, more stok look.
You will also need clutching, jetting, a/f gauge, boost controller, boost gauge, better drivers, etc. Alot to look into before you jump into it. If you do though give me a holler and i wil help you out.
i went with an MPI Stage 1 Supercharger. I dont want to climb the biggest hill and i dont want to have the highest top end. I wanted it so that i could hit my throttle, it went. The Supercharger had a pulley problem in the beginning but now that its fixed, the sled is completely turnkey. I have instant boost whenever i need it. If im in a bad situation i can pin it and instantly im making a ton of track speed and can pull right out of a bad spot.
Supercharger, gauges,clutching, install, everything ran me about 6k.
