My boost has been experiencing issues. Sled has 1700 miles on it and has runs ok up till now. It started with moderate dets. They would occur when you punched the throttle when moving along at about 30 mph. It has now gotten to the point that it seems to be in a permanent limp mode. Took it to the dealer and Polaris told them to replace the det sensor. That got done and I took it out for a rip, no det codes have come up at all. Sometimes at startup I only get 850 rpm for an idle and have to work the throttle to get it to stay running. Will clean up some around 3000 rpm but let off and back to 850 and won’t run on its own. Shut it off and restart and same thing, only idle at 850 and quit. With a few start/stop sequences every once in a while it will idle normal at 2000 rpm. Go for a drive and the sled won’t rev past 6500 rpm like the exhaust valves are closed and won’t open. Prior to the first visit to the dealer I have gotten a cold primary injector code. This is definitely not a fuel quality issue. Fresh non ethanol premium. I bumped up the octane by mixing 50/50 av gas and the issue continued. Sled is all stock with the exception of a P85 clutch and a silicone 90 on the turbo intake. I’m having trouble attaching a video.
