Boost juice
P
PIKER
Anyone had any troubles with their boost juice fuel mixtures? My buddy and friends had issues with what we think was wazzing ( looked like white floating skum) during a two day trip running premium fuel from two different fuel stations. The skum ended up glogging the pick up valves on their tm8 and turbo doos.Has anyone had problems?
Piker
Lane, the boost juice he's referring to is supposed to be a high grade octane booster, similar to octane supreme. Has nothing in common with water meth.
Anyone?
Is anyone else using boost juice and premium fuel in their rg tm8 without issue? If so how many successful miles at what boost and elevation?
Thanks in advance.
Piker
Backcountry is correct, bought it through shain from twisted. It is a octane booster and it appears to work well but my buddies did have issues their last trip and i was currious to know if anyone else is using it.
Thanks,
Piker
The stuff from kemcooil is not the same stuff, you cannot mix this stuff with any fuel that contains ethanol! It will turn the ethanol to gel, corn syrup or whatever you want to call it and plug up your pickups in the fuel tank.
So considering that ALL of our fuel in CO is now ethanol... that shoots down that idea for me (and obviously is what happened to the OP)
Thanks. This makes sense. Just for my own sanity i am going to buy some ethanol fuel and mix it to see what happens. I will post pics.
Piker
ive been using it all year, never ran E10 nor have i ever ran corn fuel in a turbo...no harm to the stocker, IMO the E10 drama is a bit over rated
currently im mixing 1.1 qts of boost juice to 10 gallons of 91 and 80ozs of redline syn at 11lbs
run the boost juice ,1 litre per tank with av gas,every once in a while i have to hook my fuel tank pickups drag them up and give them a dislodging push then no problems.seems to run good so long as i keep my boost around12 pounds.I can tell when my pickups are stuck as my fuel pump will start to whine,
