I tried to get Neils rpm map to run well and it just didn't happen. So we went back to the baro maps and its working well. Send me a pm with your phone number and I will send you a pic with all my numbers..Not ready to openly share all our hard work.
Your correct, the map I sent you 3-4 years ago was a borrowed map from a company that used to use our XICs. It was not a very good map.
Now that we have our own kits the map is completely different and uses much different settings.
We have a stock fuel pressure map for 12-16 Proclimbs and some slightly different settings for the guys that want to reduce fuel pressure slightly.
Depending on clutching and gearing, the A/Fs can be different pre boost, but will still be in an acceptable range. We add a slight amount of fuel pre boost to take care of the nasty lean spot before boost comes on.
If anyone with the XIC wants this map then email me. No PMs please.
Depending on the SW version we may not be able to hit all of the altitude settings and boost scale numbers.
