boost-it box settings
bmanke
I'm trying to get a better idea how the boost-it box adds fuel. Threshold settings. I have seen where it affects when the fuel is added compared to how much vac or boost, and also seen where they say if affects fueling at elevation. Then the Min Rpm. Will it still add fuel at the rpm you set even if the threshold has not turned on? Also trying to figure out when you full throttle it. what adds fuel first. Basically trying to figure out low speed settings, mid range, full throttle. I have had problems where I have been full throttle then get out of it then it bogs. Also when at a stand still to full throttle it will bog. Seem like it needs more fuel.
lorator
