I have a question regarding boost vs hp vs elevation on a MCX Nytro. At 12psi boost at 2000 feet sled puts out X hp. At 7000 ft at 12psi boost, is the HP still equal to X. Does a turboed machine need to run higher boost at higher elevation to acheive same HP than at lower elevations, and does it need higher octane fuel at sea level than in the hills at the same boost like a high compression 2 stroke. I was told that the MCX kit compensates to keep the boost consistant at all elevations, but the HP drops when at altitude, and that the compensater should not be used or the waste gate would need to be tightened up when in the hills.
Just hearing two sides of the coin and want help verifying it
Thanks for some info.
Nytroman
PS What event is going down in Revy this weekend
Nytroman
