Just got mine the otheer day didnt get it on for the weekend. Herd lots no one in are crew has one yet any thoughts after some miles on it.
it's a module that pulls timing as RPM increases, which allows for more boost.
The 2012 M8 program seems to do the same thing though, I've been running 11.5-12 psi on pump gas for 2 weeks now. Det sensor limitations (that I can FEEL) start at 12.5-13, and I get octn code at 13.5-14 now. The 12 program is HUGELY different from 11, at least in my results so far.
Pretty amazed at what the flash did. I've never enjoyed the sled too much on pump before, but right now I'm having a blast for way less $$ per tank.
Still gonna go back to my usual mix (2 gal 116/ tank) and see just how far I can push it though!!!
I just ordered their timing module today, you think on an 09' I'll be able to run 12 psi @ 8500+ feet on a %10 RG/91 mix?
Your setup is so different from what we run (IC, different pump, etc) I wouldn't hesitate to guess on that setup, but With how much I gained from the 12 update, I'd bet you gain a solid 2 psi minimum from what you got before.
