its a garret turbo,everything is in good shape its one of the early kits so it has the side exaust and has the orignal programing but works great. comes with complete pipe, ill even throw in both side panels with fastline vents so you dont have to cut a hole in yours and a new set of reeds all for 2500.
I'm from siouxfalls sd and you can run pump gas by getting a low boost acuator and just turn the boost down and allways have the option to run pump or race fuel i have run it on a 50/50 mix and haven't loosend the rod all the way to see how low it will go or you can leave out secondary injecters and just runstock fuel system. It also has the capaciter/rectifier and i have never had any problems running it up to 14-16 pounds for long pulls but i ran a mesh hood and no lights. It can also go on a m8
