That's the add. on your computer, shouldn't paste on a browser.
Thanks for the PDF, I want to get that tutorial, the actual boonie instructions pretty much need a translator. I have the adv instructions & a few other pages that they sent me with my various add-ons, just too lazy to remember to scan them in!
After much time on the phone & playing with the box, I have shifted to TPS mode for lo-mid-hi transition control, at high altitude (12k+) we tend to drop into mid where we have low fuel numbers on WFO climbs in certain conditions, tried just dropping the mid-hi down a few points, to get it to stop dropping into mid, but ended up with a blubbery mid. Adding tps is pretty simple & seems to be more consistent, definately smooths out the gradual throttle squeeze & at full throttle it is on hi, every time.
The LED & capture button options are pretty cheap & are very good tuning tools. You learn a lot about what the box is doing very quickly. You feel a stumble, hit the button & it shows you which setting you're in, no guessing. Want to know if you're in mid, set the LED to mid & it turns on when the sled is in mid, so if you're on a hard climb & the red light is blinking, you better have higher numbers in there.
Also with the TPS wire you can use the exv fuel if you have a powervalve stumble.
If Boondocker told people all the things that could be done with this box & explained how to use it nobody else would ever sell a box in my opinion.
