Sno Junkie
Tried it. Still hit DET sensor. Waste of money and time as far as I'm concerned. I mix 50/50 at 7000 ft and run 9 lbs. Way better performance. I tried running 7 lbs with TCM and hit DET all day long.
what turbo kit do u have, what octane mix are u running at that boost level???
Not to pick on you, but you must have made some other change to have lost bottom end.
The bottom doesn't change, so you did something else. Did you remove too much octane & start hitting det?
I'm not defending my purchase, I don't even have on on my sled, but the reality of what they do is pretty simple, and if you lost bottom end, something else went wrong I'd say.... since the key has ZERO effect on bottom end.
Yes, I added a larger compressor housing at the same time. My sled didn't idle well either. I was able to return both modules without any hassle.
Just stick a resistor in place of the Pipe temp sensor.....
Ok, so you... oh nevermind.
Why does it seem so simple, but people make it so complicated?
Resistor wont make ecu pull fuel or timing if you have the correct resistor in....!!
