Boondocker adj actuator??
C
Crusty82
Hi. How low is it possibel to adjust the boondocker adjustabel actuator?
Mine is set at the lowest and my maks boost on the stats meny says 4,3 at 7000rpm. Have just testet the sled for 5minuttes.
Isn't it supposed to go lower than that?
My ebc is set at 0,6 (set boost)
When you loosen the head all the way. Is it enough to have 2 rounds when you thread it back down?
That is what the instructions says. But to me it seems risky that you only have 2 threads holding the head.
yeah I found those instructions to be very vague.. I asked for help on it but nobody really could give me a straight answer. So take your turbo pipe off so you can stick your finger in there and feel the wastegate. From what I understand, adjusting the head manipulates the "Throw" of the actuator. Adjusting the knurled knob adjusts the tension of the spring and thus boost pressure. If you mess with the head a bunch you will find that you can make it to where when the wastegate opens it only opens about 1/8 inch.. and when the head is turned out all the way "toward the front of the sled", the throw of the gate is opened around 3/4 inch or so.
I think you have the right idea.. On mine the head is only threaded on about 2 turns, the knurled nob is all the way to the lightest setting and then backed out a turn or two in order to keep the valve shut and from fluttering when I let off the throttle. I assume fluttering is bad for the valve.. anyway im not an expert so someone correct me if im wrong. I have just played with it a bunch trying to figure it out. this gives me about 5lb..
maybe try adjusting the actuator to where it's 100% open all the time and see how it runs and what pressure you can get down to. I tried this before in order to tune it and work the bugs out before I bumped up the boost but with the bd intake I found the problem with their intake design was the mag side fouls out from not getting as much air blown into it.
Do you also have a ebc? Is it proclimb you have? I got really confused with the wiring diagram now. In the wiring fiagram for fuel booster and ebc it shows that the ada harnes, ebc harness and fuel booster harness. This is how i did it. But i saw now that in the ebc instructions it says for m8 and m1000: "Do not connect the ebc in line with the stock harnes. Do not plug the ebc into the fuel booster connector with the red and black wires" what is right?
I also thinking about the tps smart that they describe. I can understand how this can work if you arent running really high boost. When I have 50% throttle and the ebc is set for 5psi. That would give me 2,5psi according to the ebc. But that won't the actuator "allow" and I will get the minimum boost on the actuator
i have a pump gas turbo m1000 so its likely going to be different than yours if you have a proclimb.
I also have the ebc with ada and a bd box all plugged in together.. for me that boost reference line goes from the intake box to the fuel pump and they Y splits up to the ebc. That is if you have the boost reference on the fuel pump to increase the pressure on boost.
Then you have the power that's going to the fuel pump. It consists of the stock fuel pump power supply. It also consists of a 12v AC output from the steering post harness going into an AC/DC Rectifier (little black box) and then combining with the dc power supply going into the fuel pump. This is so that the pump can put out a little more pressure with the extra current supplied from 2 sources I assume. My pressure with the bd pump and regulator is about 45psi.. (the bd pump looks just like the stock pump but it is a little higher pressure).. i think. dont know for sure since I bought sled used.
my kosos's are ran off the sled's oem fuel pump supply since that's 12v dc power.
The plugs into the ebc and everthing were pretty self explanatory plug and play. None of the plugs should have more than one matching mate.
Im doing all this from memory so i cant recall the rest.. I would have to look at it again. most of the plugs were labeled "Warning, connect to fuel pump only" and things like that.. your best bet is to trace the wires and try to understand how everything works and what senses what. It should all be pretty simple once you wrap your head around it..
Thanks alot. Yes i also thought it was real easy when i did it. I used the wiring diagram in the instructions and I always tried to watch for other matching connectors. But it didn't seem to be possibel to connect it wrong. I have tested the sled for 5 minutes and everything worked. It ran great and i didn't get any errorcodes. So i guess i did it right.
But when reading thru the ebc instructions today i got confused.
