Boondocker 2012 kit on 2013
Turblue
Anyone one know if a boondocker pump gas kit from a 2012 could be installed in a 2013 pro rmk with belt drive? I realize the bottom mount would be different but anything else? Control box work?
I don't think the control box will work...not sure though. Although if it doesn't have the upgraded box that is worth doing.
From what I can find out a new box is required, timing key, modify bottom mounting bracket, quick drive cover
If you are going to use 2012 box on a 2013 or vice versa, you need adapter. Talk to boondocker, they have it.
It should work, I have a 12 kit on an 11 with a 17 fuel box. If it has the stand alone boost controller you may need to upgrade that as they can go bad.
