I found a series of posts on Snow and Mud.com about using a bolt through the ski by the spindle as an ice scratcher. I'm new at this so I was curious what you guys thought. Does this make sense or is it totally retarded? It kind of seems that it could go either way. It seems this would eliminate some of the problems associated with spring wire type scratchers, like backing up or getting caught on stuff. Below are three of the posts that I have cut and pasted here:
I use a 1 3/4 inch bolt on the inside back corner of the ski. The bottom of the bolt is about 3/4 inch above the ground when on something hard like the trailer deck. When you go down the trail and the ski drops into an old skeg track then it contacts the snow and sends up a spray of ice chips to lubricate. They don't seem to affect steering probably because they aren't in constant contact with the snow. I never remove them (except to replace them when they get too short) and have never caught them on anything in 8 years.
yup............ what Summiteer said!!!! put a 3/8" bolt in the inside back corner of each ski & away you go........... no worries about lack of lubrication or over-heating anymore. don't have to worry about reverse either. just remember to take them out at the end of the day.
Got ours drilled behind spindle on ski before it curves upward.... Works awesome giving alot of spray. Just use a couple of washers & double nut the bolts.
