bogging and occasional backfire 700 RMK
Hello , I am having some issues with my 06 700 RMK 159 , a couple of days ago it started to bog out after the clutch was engaged on a full throttle start it would feel like only 70 % power then after a certain RPM it would clear itself out and rev fine also it would backfire occasionally . I have checked the TPS wiring from the TPS too the computer and seem to have good consistent resistants through all three wires and both connectors i have also checked for airt leaks at the intake boots ????????
Are you getting a check engine light? Have you checked the plugs? Change your fuel filter?
could be a few things.
-fuel pressure
-fuel filter
-stator going bad
-tps has dead spot
-tps harness seperating
-hole in exhaust bellows
-poor fuel/DET
-ingesting snow/water thru intake
