bog issue
2014 pro. started with a PCV and couldn't clear up a bog that would stick me at 7500 rpm and snd terrible. I now have a boondocker box with numbers other guys are running. still have the same bog. Only happens when I pin the throttle.
so far I've swapped the EV solenoid and the throttle safety switch. did not fix it.
I do have a RSI throttle block.
tuesday I'm taking the sled in to have the tps checked.
has anyone else had a similar issue?
Posted from Snowestonline.com App for Android
I'm running an RK TEK 858 in my 2014 pro. started with a PCV and couldn't clear up a bog that would stick me at 7500 rpm and snd terrible. I now have a boondocker box with numbers other guys are running. still have the same bog. Only happens when I pin the throttle. I can ease into it and pull 8450 rpm.
I have a bone stock 2014 with 300 miles on it that started doing the same thing yesterday - anybody have any ideas? Hitting the rev limiter maybe? Heavier weights? Dealer is suggesting beefier plug wires maybe?
I'm pretty certain I'm not hitting the rev limit. running 66g at 7k elevation. I believe that what other 858 kits are running
I would try a couple grams heavier if your able to. Especially if your able to ease into the throttle and hit 8450.
Might be reving up too fast and giving you a bog.
I was told to run it around that rpm range. but I will add a gram and see what happens. yes I am running a koso afr gauge. I'm running Kinzers numbers and the afr seems in spec. It was a tad rich so I took a little fuel out. Does anyone have boondocker 13rpm map they want to share?
