B
bcpowder
I’m on my 3rd Ctec2 800. Had the 18, 19, and now the 21. All have been awesome.
I run bone stock with a speedwerx muffler as the only modification. I’ve had the same Can on the last 2 sleds without issues.
My 21 has been having real bog issues at WOT. Sounds a lot like when all your air intakes get plugged and it won’t rev up. Only thing is it happens often when the air vents are completely clean. It also will happen mid climb with the skis in the air fully pinned. Off the throttle and back on usually clears it. so it doesn’t appear to be an exhaust clogging issue. Clutches seem to be running smooth as well.
I assumed it was just a break in rich fuel issue, however I’m now at 12 hours and it’s still happening. I also checked the power valve cables and are both bang on 36.5mm
has anyone else experienced this or found a solution?
