Blown Up Boondocker
I ran mine at 13-14 on the air/fuel, never had a problem, in fact, was told that is what is needed to be. Lower is rich right? Or am I wrong?
11.5-12.5 that is where you want it for best performance on a turbo sled or turbo motor in general.you mite have had a blade break off the impeller but it would tough for it to work its way into the motor but it could happen.
not sure if you are still down and out but I have a fully built apex turbo motor that has not been started and it is for sale. Guranteed to take some BIG BOOST! :)
this was the motor builders to-do list
- Wiseco Piston Kit 10:1
- Big valve conversion
- Valve spring kit intake and exhaust
- Carrillo rods
- Rod bearings
- Gaskets/seals
- Disassembly
- Crank balancing
- Blue printing engine
- Porting/polishing
- Performance valve job
- Assembly
