I saw a 2012 pro that was truly murdered out. Black tunnel and all. Try to get pics posted later.
Polaris extreme it is. Lots of sand paper and polish and elbow grease![]()
Mine is close to all black.
Looks great!
If you're gonna "murder" it, go all the way. Loose the decals and leave the grills black![]()
Yup, I powdercoated mine.
It's "matte" black actually. Black base coat. Two coats of clear coat with a flattening agent in it. Looks like flat black but more durable and scuff resistent.Did you paint the side panels flat black?? And what kinda paint did you use on them??
smokin.Mine is close to all black.
For those of you looking for ideas for color schemes. This is my 2011 Standard RMK. It came with a red hood and black side panels. I switched out the red hood for a black one and removed the red decals from the side panels. I also cut the windshield down about 3" with tin snips and cleaned it up with a bench grinder. I used small automotive vacuum hose for trim and sliced a slit down one side with a razor blade to make it fit over the edge of the windshield. Super glue to hold the trim on. So if you want this looks you could get some 2011 Standard side panels. I'll post a before and after.
I'm still considering removing the 800 decal or maybe both side panel decals and just leaving the white Polaris decal. Thoughts??
I got the hood from Babbit's for $107.00 shipped to my door. I did not order the $70 foam kit. I'm just going to use heat reflective tape in the spots where the foam was.
Here's the link for the hood: http://www.polarispartshouse.com/#/P...NS/86857/86866
Is the only part you needed the 1st line item for $90.19? That's cheaper than painting it.
anybody have a parts number for a red hood?
Yes that is the only part you need. It does not come with any hardware whatsoever (i.e. spare belt holder, screens, 1/4 turn clips) You will have to swap that all over from your old hood. You will need a sharp #13 drill bit to drill out the two rivets holding the spare belt holder. Also will need a few torx bits (T,25, T27, T30 i think were the ones I used.)
The hood does not come with foam. I plan on using a little heat reflective tape in place of the foam on my new hood. The foam kit is $70, so... no thanks.
Here's the link for the red hood
http://www.polarispartshouse.com/#/...._-_S11CM8GSA//GSB//GSL//GSM//GEA/80551/80557
Part number: 5437509-293 it is $337.
