Bigger turbo nytro injectors
1madbird
Who has went to bigger injectors on there turbo nytro how did it improve and was it worth it?
I have them but I would not recommend them if you are going to run 15 or less. from 16 up they are essential but I think they deliver too much fuel for anything less
I got a set from paul at impulse and love them. I was running higher fuel pressure at idle with a 2 to 1 reg to try and ram the fuel through the stock ones at higher boost, so I seen a increase in bottom end response. The stockers were letting to much fuel through at low rpm's because of the pressure increase. I would tend to think it is running out of fuel at about 14 lbs, thats what my air fuel was saying with the stock set up. I have a pl control box and with the injectors my response is still excelent.
They work great at all boost levels, you don't need them below 12 or 13 lbs but above that you will for sure. We have them in stock $499.00 for the 750cc type.
