A few questions on install.Do you remove upper running board braces and flatten out factory grips when installing??
Thanks in advance Autopro
I put in Snow Eliminators. I layed the Eliminator down then traced around it with a sharpie. I used a grinder with a cutting wheel (very quick). Then I flattend out the raised stock foot rest snow eliminaotr holes. Then I went back and cut the little tabs left over from flattening them out. Here are some pics, hope they help.A few questions on install.Do you remove upper running board braces and flatten out factory grips when installing??
Thanks for the help,I thought that is the way it should be done.
Autopro
