Yeah its a bit pricy thanks dave i wish i woulda seen that! I ordered red anodized and with black wheels. i hope the stock axle will work.
Ice Age rails, unless recently changed, requires an 8" wheel minimum. You can use your stock axle, but they require bigger rear wheels. If you run the stock wheels on the Ice Age rails, the end of the rail rubs/clicks on the metal clips of the track and will prematurely wear out your track.
they must have changed that or maybe its an option. my Ice Age rails are set-up for the stock Polaris wheels
whats the difference between the bomber rails and the regular?
Bomber rails have less weight saving windows cut in them and are thicker. They basically are solid rails. They also cost more.
