What makes them so much better. Ride, no fade?
I like a shocks that are soft enough to isolate me from stutters and smaller bumps but stiff enough that keeps the sled in control in the big holes. I know there is a compromise because no shock does both well. I believe that is where dual or tripple stage spring rates, or valving comes in.
The Zbros look like more money than I want to spend however, if they do what I explained above well it may be worth it.
What makes an Exit shock superior:
Larger 5/8" shock shafts, stays true and takes tons of abuse
Remote resiviors: they hold more oil so the shocks don't heat up/fade under aggressive use, greater oil volume allows you a to run a more aggressive valving package without killing the ride and the ability to make precise adjustments. (compression/rebound adjusters)
The shock oil paths are much different than an OE shock or a Fox, this allows the shock work easier, the oil doesn't heat up as much and helps deliver longer life between rebuilds.
Triple rate springs, three springs rates with crossovers give you the ability to have a spring rate for small bumps, one for the medium bumps and a spring rate for the large hits.
Valved for your weight and riding style.
30 Day Ride quality gurantee, spring rate changes and valving adjustments
MADE IN THE USA!!!!!!! With pride, no low bid quality pieces here.
The X1's which offer compression damping adjustment retail for $1050, not the $1105 previously posted. The X2's are available and add a rebound adjustment for $1250.
The Fox Shocks tout a lot of adjustment, its nice and if your shooting 100' gaps or drops you may need it, but in most situations I find the adjustments to be ignored after a while, most people simply refuse to continue messing with shocks daily and most never want to play with shocks for weeks on end. Most guys want a significant improvement in ride quality and hard riding performance and they want the shock to work without constant adjustment or attention, be durable/reliable and deliver a smile on their face after a days ride knowing their hard earned money was well spent. Its a tough bill to fill, but the Exit brand shocks do it very well.
