Best setup on 09 assault, deep powder, light rider
C
colo-chinaman
New member
Hey everyone, new to this forum, new to the sport, so hello, and I look forward to hearing from you guys and giving input where I can.
I recently bought an 09 assault 800 with fix kit and 163 track, via ice age rails, I believe the tracks is the stock track from a dragon.
First off, and I feel half my problems are attributable to the fact that I am small, 5-7 and 140 pounds on my fattest day
I had a helluva day in the deep today, for one the snow was REAL deep, up to my chest in areas, and I am a fairly inexperienced rider. New to deep powder anyway.
I feel I have the basics down with regards to leaning hard, countersteering, etc.
What I am trying to figure out is what is the best setup for the deep powder for someone my size. I seem to have a hard time getting the sled to roll side to side. I can do it, but it takes me hanging off of one side, hard countersteering, etc. its a workout. Where I run into problems is on and incline or decline, with a slope also going down left or right, its just so much work to get the sled to roll uphill so I can setter into the slope and stay upwards.
Also the sled seems to dive more than necessary when I let off the throttle which instantly stands me up and I have little to no control over what it does
Today i got stuck a ton, mainly in areas mentioned above and I feel if I could control better I would not need to get into situations where I have to hope for the best and rely on speed
I have read to move the limiter strap bolt from the middle position down to the lowest hole which will reduce the approach angle...maybe thats what I understand?
Also loosen all shocks to be as soft as possible, how?
Picture one shows ft track shock, box 1, is this about right for the spring rate or should I back it off? Box 2 shows another adj but not sure what.
Pic 2 shows rear track shock. an adj, I believe its set to soft all the way, is this wise and what is it anyway. Also is this the only adj on this shock
Pic 3 shows limiter strap, its in the middle now, should I move it to the bottom hole and would that decrease ski pressure and alleviate the diving/get the sled on top of the snow better, what else would that do? Also the ft track shock position, I read to lay it down which I suppose means to move the position to the 2nd hole to the shock is closer to horizontal? what does that do?
Pic 4 shows ft standard assault shock, box 1 is what adj? and what should I do with it and why? box 2 shows another adj, currently down to the 8 line which means???
Pic 5 shows the where something bolts to the tunnel, maybe some shaft of sorts. On dragons I remember seeing multiple options here. I read that moving this up 3/4 inch should help but no hole, do I drill one and why?
I feel that if the sled rode even more on top than it does and it would be "lighter" or easier to throw side to side it would help me a lot. I am also sure a certain amount of learning is necessary, just want to make sure I am not working harder than is necessary. from what I understand the problem with decreasing ski pressure is lack of turning control on hardpack or minimal powder, thats kinda ok with me as I am not really in a hurry in these situations. I would also like the ride to be as plush as possible as I keep jumping to a minimum, mainly a few feet off of drifts into more powder.
Thanks in advance!
20130203_184214_resized-1.jpg 20130203_184536_resized.jpg 20130203_184121_resized.jpg 20130203_184403_resized.jpg 20130203_184223_resized.jpg
Also for anyone wondering. I realize the sled may be a bit much for a semi-newbie however I mainly wanted something I could grow into, and would be great in powder after a certain learning curve. I feel after reading a lot it was a good chassis for me, good factory weight, good reliable power (with the mtntek fix kit) etc. Maybe a touch long but hoping that is workable.
Also I will adjust the skis narrower is hopes that this helps a little. currently its set in the middle
Trade the front end with a narrower RMK, this would help you alot...
You need to just try changing things around for yourself, its a preference thing. Just change one thing at a time so you know what effect it had.
I prefer my front track shock in the lower mount location. My sled gets up on top of the pow much faster. I also like my limiter straps in the middle location, keeps the skis nearer to the ground.
