Best place to get parts locally
O
octanefam
Sort of new here but anyway I'm in the process of putting together a Mountain Max and need just a couple of more parts by this weekend..... Was really hoping to get this bad boy done but found out that the Steering Tie Rod Ends that I had were stripped so I need two hopefully before this weekend. So what is the best place to get parts locally that has them IN STOCK. The one place that always has the parts that I have needed in the past is Sportland in Cle Elum but they only have one of them.
Oh and if someone has some they want to get rid of that will work with a 2000 Yamaha Mountain Max 700 I will buy used too:D
Thanks agains,
Todd
Willing to help you out, need a little help from you as to what is local? Can't tell from your post where you reside.
You may want to try the Sled Shed between Tacoma and Sumner, in the mean time I'll try some buddies that ride that same sled.
Check with Harbor Freight they may have rod ends. If the rod ends are stripped are the tie rods bad as well? You might try a machine shop in your area and see if they can come up with the parts you need. Sometimes it can be faster to have new tie rods made and as long as the rod ends are available even though there metric it should not be too big of an issue to do this.
