B
blackcloud2k
That is the old style VE bumper i have that one on mine, but it does not work well for the 09 conversion .
Why doesn't it work well with the 09 conversion?
I have a Vanamburg bumper off my 07 M1000 162 to sell with an LED tailight, went to a CR Racing tunnel, exchanger and bumper. Best offer, I am in Alberta.
Adrian.
Im sorry, but what is wrong with the stock bumper ?
Thanks
c
Thanks
c
Do you have to use diodes with the LED tail light so you dont get backfeed?
I have completed a number of 09 conversions including 09 heat exchanger, LED, flap/bumper, etc. They go together fairly smooth, only two minor issues, first; on 05 to 07 the running board edge grips lack a couple millimeters of matching the holes in the tunnel so some drilling is required, second; the 09 rear heat exchanger employs 2 short hose elbows, these elbows require one leg to be one inch longer to reach the stock exchangers, so a trip to the auto parts store is necessary. Otherwise wiring the taillight is the only other item which is not a direct part replacement. They look great and are very light and strong. Not the cheapest or the easiest (gotta give that to BD Extreme), however the 09 conversion is definitely my vote for the best.
For those thinking of Flattening their own heat exchanger, keep in mind this requires bending and cutting the tubes as well as a likelyhood of minor welding. I found this to be the case while fabricating a few custom rear tunnels last season.
LED = Light Emitting Diode.
Can you explain what you mean by using a diode to prevent backfeed? If you put a diode in line with another diode, you just increase the voltage drop.
Mountain Doo - Can you post some pics of what you did. Sounds like it works good.
Well if that gas rack dont look like sh it turned sideways Doo.
