Avid drivers 2011 pro rmk shaftwhat drivers do you have there?
and what year is the steel shaft from?
thanks
thanks
i know, i have one from my ‘17 sks.
reason i asked is because i just pressed avid anti ratchets onto that shaft and the positioning of them looks different than what sheetmetal has.
my measurements are dead on to the avid instuctions/measurements.
i am curious why the difference; drivers (powder freaks maybe), shaft year, etc...
question:
does these rail cuts for an anti-stab look right?
cut distance from cross shaft mount hole is 1/2".
cuts are square to tip up in rail.
the hyfax is not tapered yet
it seems to me like the bottom of the rail is protruding too much.
I am thinking the cut needs to be more perpendicular??
Is that the mtntk kit?question:
No.Is that the mtntk kit?
Sent from my SM-G973U using Tapatalk
No. It is the Avid kit.Bevel it back (mostly hyfax and a little aluminum) and smooth it out.
Should be good.
No.
That looks like a BDX 2 wheel anti stab.
Ok it didnt look rightNo. It is the Avid kit.
It was the only one I could get before my trip coming up.
I will call Adam and see what he says
Wonder if you could trim them back a little and re install the front capfinal product. I ended up radiusing both profiles of the rails, then matching and contouring the hyfax. don't think i will have any issues. after all is said and done, i don't even know if i needed to trim the rails and run an anti-stab. it appears there would have been at least 1/8-3/16" clearance, if not more, between the rail tips and the extroverts.
