Good point, but a good brace kit will make it way stronger then stock...all depends on how well straightened it was and how good the brace kit is and how it is installed...The one thing that nobody has mentioned is that you can straighten it but, you shouldn't. As an aluminum welder and fabricator once aluminum is stretched it will never be the same. You can get it close but it will always be weaker than it was originally and you can brace it but it will be more likely to bend in that same spot. I have repaired tunnels a few times and it always bent in the same spot again until i just replaced the tunnel and was done with it. As long as you got the money set aside fix it the rite way with a new bulkhead if needed and a aftermarket or stock tunnel whichever you prefer.
Not really..when Mark did his van amberg(of course van amberg may brace the joint now), he ended up making his own bulkhead braces to make sure his didn't bend down the road...... I love some of the aftermarket tunnels, but I wouldn't install any tunnel on a pro without making sure I braced the bulkhead joint..
Mark(snodawg on here)...http://www.snowest.com/forum/showthread.php?t=318305
It's not rocket science.. it is actually pretty easy as long as you go slow, pay attention and don't just start wacking at it with a BFH...biggest deal is to exert force exactly opposite of how it hit..and go slow..may have to work 2-4 areas at a time...Yeah I thought about that myself. I'm no metallurgist but I do know that part of the tunnel will never be the same. That's why I'm apprehensive about stretching it back out. I did read yz's thread earlier and it did instill some confidence so maybe I will give it a try. I whole problem here is that I shoulda been working on this all summer so it wasn't such a rush but instead I wasted the summer chasin girls and drinkin cold cervasas.
