Bent skid?
I must have done something to my ride last season. The track is rubbing on the right side of the tunnel, but has a 1/4 inch of clearance on the left. What can I do to move the track over? Thanks guys, I'm a noob at this stuff.
first off, check your track alignment. since your new at this, have you an owners manuel for your sled? loosen rear axle.spin the track using the motor. tight right, tighten right. tight left, tighten left. take measures off the hyfax at the rear. keep playing with it till is even on both sides. sometimes on a hard hit, you can knock the skid out of square, but this is a whole different ball of wax. check alignment first, go from there.
