If you look at where the stearing post mounts to the frame, you can see that it will be bent to on side or the other. Also when my frame was bent, the lower left arm went back and it pushed the lower right arm forward. I tried to straighten the frame by tweaking on the a arms with a pry bar, it just bent the a arms. Sometimes it is hard to tell if the a arms are bent, paint might not be chipped. If just one arm is off it might just be the a arm, not the frame. The only way I first found it was the frame was by putting on new timbersled a arms and everything was still way off, then I saw the stearing post mount was way off.
