Bender Stage 2 Turbo package from RX1
K
kenlacy
New member
Rear mount - Bender Stage 2 Turbo package - includes everything you need
Large innercooler
Garrett M24 Turbo
Blow off valve
AEM Electronic Tru Boost controller - use presets or adjust on the fly. Never worry about your fuel and boost.
AEM Digital Wideband Air/Fuel Gauge with Bosch Sensor. Sensor mounted after the turbo.
Original installation istructions/manual.
I kept as much as possible intact when I disassembled it so it will be easier for you to install.
I am including my old heat shield as it has been modified to fit over the turbo.
I ran up to 17 lbs of boost. This thing hits wicked hard! Cruise along at 80 mph 1/4 throttle and then punch it, skiis come off the ground until you're geared out at a real 120 mph in no time. Change from stock gearing and you can do more. This is at sea level.
$2800 delivered in the lower 48
I will have the engine up for sale soon - with JE 10-1 pistons - just have to get the clutch pulled. Message me if you are interested.
Turbo
Fuel System
Innercooler
Oil system
Charge tube
Charge tube 2
Electronics
Pod
Answers to some questions that were asked:
Roughly 2300 miles on the kit.
Only problems I ever had were an exhaust leak from a non-turbo part (flex tube) after about 1500 miles that caused a lot of lag. And the boots from the carb to the innercooler came loose after hard landings on some good size jumps - easy fix.
I had JE 10-1 pistons. I do have another head gasket - new in the package p/n 8fa-11181-01 that I never used because I went with the pistons. It is included if you want it.
Freight is included to Canada as well. Duties/taxes would be up to you.
