do you have objective data ?
feel , and noticeable ,, are there any quantifiable values you can associate with those terms ?
If your going by hunch , I would suspect yes rotating mass in the motor and primary would allow the motor to spin up faster .. BUT only until the belt is engaged.
once the entire drivetrain is loaded from the motor to the snow . then it wouldn't matter.. the amount of resistance from the track spinning would be 100 times your reduced mass weight . so what was a small value of a idle speed motor load to a VERY VERY small value of a engaged load.
you sell and buy these lightweight drivetrain components ,so you drank the koolaidlol
when I was developing products , we would test them for consumer liking.
if the test variable would pass parody plus 10 points meaning 50 50 plus 10 points , then the juice might be worth the squeeze
to the loaded resistance argument:
nxt post
Wrong. Wrong. Wrong.
If life after loading a track doesn't matter then why do people buy a turbo?
There is a post above where CMX tested the belt drive against a chain drive. He used a drill to spin the track with a scale to tell the force used to turn the track and showed the amps used to power the drill. The math people can tell you what Horse Power is used to turn the track in both situations. The belt drive takes less HP to turn the track. This allows that unused HP to be used in spinning the track faster when loaded. This may be a small issue to you when you are playing with 180-300 HP. Now look at it when you are on just 60 HP. The benefit is now much greater.
