Not unusual, more so if the bike is cold.
M5
M5
The brc 500 is another option with no actual on snow reviews. (More expensive)
I'm new to the snowbike world and picked up a low houred 2015 KTM 450. I put a Rekluse on right off the bat and have noticed that nine times out of ten my bike won't start unless i'm in neutral even with clutch pulled in. Wondering if this is pretty normal or is there something out of adjustment?
Thanks
The important thing is that you got one. Now get out there and ride that thing.
Just got it and riden it in the heavy melting snow. Husaberg rocks in low and mid-rage, what a sound with Acropovic muffler!
After lifting it after falls in deep snow on the hill - no, I do not want anything heavier. No sportbikes for sure
Thus, more beginner questions:
- the bike came with pretty high clearance and steep track forward angle. Pulls great, but very difficult to get on, and difficult to stop (and I got long legs
I have lowered the bike 3 inches down, by ajusting the angle of the track to bike frame. Very comfortable to sit now with both legs on the gound. But the track got very flat in the front section.
How does the track front approach angle affect performance on the snow? Shall it be steep or flat in the front section?
a 15 wide track would be harder too lean over and it would also stick out width wise past the pegs and be easier to catch on things. As far as length goes, Longer you are the less you can flick it around like a bike and ski pressure gets annoying. I think longer will be easier handle on custom built bikes when they get the track up under your feet, getting the center of gravity better and overall length down.
So changing your strut length is doing more than just changing approach angle and lowering the bike, you now have more fork rake and your tack isnt sitting flat it will be as* up and you probably wont like how it will trench. get your track sitting pretty flat and make small length adjustments to get the ski pressure how you like it. you can tweak fork height too. I would just get a low seat and send it. the lean back can work but its not preferable to go extreme with it.
