Newtons so called prehistoric law's of physics are currently be disputed by many with proof and are being found wrong.
. Try hammering a nail with a small hammer and then try it with a heavy mallet.. tell me which one drive the nail further, faster?
Kelsey
I like this but think its more like this. the na motor or "hammer" is rite, but the turbo motor is more like a slowly increasing push on the nail due to spool up time, not instant impact of power.
I don't know...what do you think? sounds good in my head lol..
Y Try hammering a nail with a small hammer and then try it with a heavy mallet.. tell me which one drive the nail further, faster?
Kelsey
This is quite an amusing thread for sure. It sounds like some of the absurd comments have been to yank Kelsey's chain. But in case there is some newby, or mind full of mush that would actually beieve that making more power, or flowing more air would make your crank last longer, don't be fooled by anyones "clever" use of the english language.
All foolishness and humor aside, the crank life of a motor at 8500rpm at 1/4 throttle will be much longer than the same motor WOT at the same rpm. More power (associated with additional airflow) will decrease the life of the crankshaft.
There are other factors that could skew this observation. And they might contribue to misconseptions about cranklife being extended by added hp. And such factors can mask reality.
Deto, poor lubrication etc. will kill any crank prematurely. That is not the issue at hand. And to assume that the added airflow of the turbo magically adds oil distribution to the crank in a way that overcomes the wear of the added stress of more hp is just wrong.
It is the same incorrect assumption that the WOT motor at full power will have better cranklife than the same motor at 1/4 throttle. It is the same comparison as a naturally aspirated motor vrs. a turbocharged motor.
I really have to wonder if someone here has stock in Crankworks, or Twister Crankshaft. And they have indicated that turbo/mod sled motors are providing plenty of business. Lol
It might be that some might try to make this BB vrs Turbo discussion. But it is a fact that poor motor setups might contribute to undue crank stress, But in general, more power=sooner component falure. Simple as that.
kelsy you are deffinately the smartest guy in the world on 2 strokes and your right and now I lie when I state personal experiance or opinion.
at least you had all day to spend checking this thread. I wish I could have argued with you all day but no time sorry Maybe next summer.
Poor old Product Tester...Why does Everybody have to Pick on good ole Product Tester...
I do agree 150% with Kelsie on this one. Product Tester...I have seen more Crank Failures in Turbo Sleds than that of NA sleds. I ran a DD 1010 kit in my King Cat and that thing ran awesome. There wasn't a NA sled that would run with it, except 1150's. Ran at least 2000 miles on that crank. I sold that sled to a friend of mine and the crank is still running good.
More Pressure=More issues with parts. I have witnessed it first hand. I think that the issue that causes the most wear and damage is moisture in the fuel, poor lubrication, and poor tuning (Lean conditions, poor clutch ect). All three at any given time can create heat on the crank. Heat causes wear on the bearings and can set the crank out of tolerance. The clutch out of Balance creates more pressure and heat on the crank. The seal missing Causes more heat on the crank. Poor quality of oil...causes more heat, Thus putting much more opportunity for wear and tear on the crank.
The funny thing is about this dramatic thread, is WHO REALLY CARES!!!! I feel Dang lucky to even have a sled that could possibly break a crank. I just hope it doesn't break when I am drag racing that Shain Stanger Custome D8 Turbo, Cause I am going to be pushing so much boost that it just may go CA BOOM!!! Then I would have to be towed out by that Custom D8T.
That would just make me sick.
oh and Radski if ya dont mind my restrooms need restocking.
I total agree with Shane and Gus with the idea that some pressure in the bottom end is going to grease the bearings up more. Your bearings are under load there are X amount of pressure on the bearings to the races and it is all riding on a film of oil. Boost it and you got X amount of pressure in that film of oil now. How is that not going to work?
Simple question.. What is to stop this added pressure from blowing the oil OFF of the bearings?? How is this oil directed?
Got to like how some folk are slamming the Idea of how boost creates less stress on your crank. Well that is not was said and if it was I sure do not believe the person meant it.
by productester. The turbo is alot easier on the crank than assperated because of the smooth power and everytime you boost it forces the oil everywhere.
