The stock polaris wide crank bearing on the pto side is junk. It uses a spring cage in the bearing, it's likely built in China along with their wiring harness. The cage spits out and ball bearings wad up...fails.
One of Indy Dans upgrades to the long rod crank package he sells is to replace the wide single bearing with two higher quality bearings and an additional ring to carry pto crank end load better.
