I have a 07 m1000 with the reflashed ecu and a can otherwise all stock. I was thinking of buying the bdx pro lite power vavles but I don't have a boondocker box or some other fuel managment system. I was told with this kit comes a bog or a sputter at bottom end and you have to adjust your fuel amount.
I was also told you could skip past the bog if you make your sled engage at a higher rpm if thats the case is it safe for the motor not adjusting the fuel and what color spring do you use?
Also anyone running these on this same sled and how do you like them
