Just upgraded my 2011 PG to RG kit.
How do I set up the auxiliary injectors on the control box??
Seems like they don`t work.
Did not found any instructions about this on Boondockers homepage
You will need to change some of the numbers in your control box to add the upgrade fuel system. Please follow these steps:
While powering the box on, hold the left and right arrows, once control box is on release the left and right arrows.
Tab over through the RPM setting until you get to the Fuel setting, select the Fuel setting; scroll to the PSI L, select PSI L and enter the numbers listed below for PSI L press enter. Then scroll to the PSI H and enter the numbers listed below for the PSI H press enter.
Power the box off. Power the box on, while powering the box on hold the left arrow button and the select button release the left arrow button and the select button once the box is powered on. You will now want to change the RPM setting to the numbers listed. The box is now ready to for use.
If you have any questions or problems please contact our electrical department 877-522-7805
For 2010 and newer sleds use these numbers
PSI L L M H OS
10 25 39 20
PSI H L M H CR
10 27 48 21
RPM 3000 5000 6700
L M H L M H L M H
0 0 0 0 -2 -4 0 -2 -4
For 2009 and older sleds use these numbers
PSI L L M H OS
17 28 46 20
PSI H L M H CR
15 30 48 21
RPM 3000 5000 6700
L M H L M H L M H
