BD box injector error?
Keep getting injector error on bd box on m1000. Sled seems to run fine cant find nothing wrong. All wires and connections seem to be fine. Any ideas would be appriciated. Thanks.
Did you just install it or have you had it on and is now starting to act up? I had a similar problem when I put mine on, wired according to directions and good connections but still got pto error. I made up some jumpers to test to see if the wires in the black connector were swaped and they were.
Make sure the main harness for the box is routed away from anything electrical. I had an F7 that had the same problem, found the harness was by the coil and then the main key switch, re-routed and bought some heat reflecting loom and covered everything with it that ran by anything electrical, fixed it and ran fine for over two seasons.:beer;
