Got out today, snow was real deep! Enough that my BD filter through the hood was getting choked out by snow.
As for my sled it popped once all day and never had a low rpm at full throttle like described before. Only thing I did was run straight AV gas instead of a mix to 93 octane. Guess I will be running straight AV gas from now on. Will be adding more vents tho for the heat.
What I'm not liking about the comment on running 100 oct is that supposedly "all the fail safes" are still supposed to be in the evo flashes. So... Octane fixes it the backfire its likely detonation which is not being retarded by the ecu, no?
Hey 10003514 how does the BC 250 pull, do you feel its making that kind of power? have you climbed against a stock 1100 turbo? Have you tried it against a turbo yammi? with 250 hp you should be very close to a 270 mcx nytro. just looking for some feedback on 2
I would like to hear jim weigh in on the idea of needing more octane. But here is my fairly good guess.
Some sleds stock can get the octane code on 91 octane. Some don't. At this there must be some variables coming into play. The first thing I suspect is likely a possible variance in the fuel pressure. Is it possible that one regulator for example makes 60psi while the next makes 57 static? With this I am pondering if an adjustable fpr would be the ticket. I am thinking alot of the knock could be coming from a lean condition that some even see on a stock config. Crank up the fuel pressure a fuel PSI and bam it is gone. DDracing sells an adjustable reg for $149.
If you have been around turbos for a while you know that a few psi low can produce a lean mixture. For example if the sled is at 12.5A/F at WOT and knocking maybe 11.7A/F would fix that? While it would fix it, it would unlikely cause it to run any different in the seat of the pants feel but make the engine much happier?
I think Jims(evo) tune is spot on but it can't account for these differences.
Now that is just me thinking out loud. I personally have never seen a oct code on my sled, And I have even been running 91 oct in mn on the 93 oct setting. Hopefully Jim will come on and add his 2cents.
