M
MacDawg productions
Anybody change this battery lately? I just noticed that my battery light is flashing on the mfd for the first time. Goes up to half battery gauge when running.
Brutal. I had a funny feeling it had something to do with my stator. No issues with lights or anything. Not sure what to do next. So there isn't a little battery in the mfd that can burn out?
You bet, there is a battery for the MFD, but the manual states it is for clock memory. You voltage gauge you noticed flashing has nothing to do with this memory battery.
As Seth mentioned, you may have stator problems, or a wiring or ground problem. Watch for other symptoms like dim headlights, runability, loss of hand/thumb warmers, and start testing stator output.
the last 2 900 i have see have low readings on the mfd gauge have been bad capacitors no running problems but the capacitors were bad sucking up the voltage. when you are running the gauge should read all bars and all but on or 2 at idle. for what it is worth
I know the capacitor is on the left in front of tank but where excactly is it and what does it look like?
